Loren just got some iirc? There is someone who does it aftermarket I just cant for the life of remember who. Dont think nzbrake co or dba do them. Ive done a bit with race brakes and had pretty good pricing. Think pro wholesale do them tho.
Mine are znoelli, from pro wholesale as well...
Part numbers:
ZR40.019.01 REAR STANDARD 290 67.5 58 18 16 5 190mm H/Brake Drum
ZR40.019.02 REAR S6 290 67.5 58 18 16 5 190mm H/Brake Drum
ZR40.019.03 REAR S12 290 67.5 58 18 16 5 190mm H/Brake Drum
ZR40.019.04 REAR DDS 290 67.5 58 18 16 5 190mm H/Brake Drum
wel,l trw dont do it, nethier do partmaster, or repco, or bnt. Only people that seem to do it on the shelf is znoilli and ASL. But hell peoples listings are fucked up
yeah i had to get the DBA numbers to cross reference since the DR9269V with is off NZDA. So after that fronts are DBA 650 and rears are DBA656 (190mm handbrake)
BNT, Repco and Auto Brake & Clutch all have the wrong parts numbers for these... it\'s easiest just to ask for disks for a GDB WRX... they have the Subaru 2-pots.
did that and all looked at me like i was from the moon and gave me wrong numbers. and not all gdb impreza\'s have the 190mm handbrake from memory
No, but if you tell them a GDB WRX with a 290mm disk and 190mm hand-brake they can find it easily.
well i told them that too as well as a gc8 with a 290mm rotor and 190mm handbrake still couldnt find it, so all faith in humanity lost :P
ASL were the best money for quality, if i going to a slotted on i would just go and get them straight off znoilli like i did with my pads
Sure its vented vs solid tho so diff thickness. There is a diff it may be a 2 pot with small ebrake or something.
