What engines will fit a version 2
Zach
Need a new longblock or complete ej20 engine for a version 2 wrx. Im curious as what my options are in terms of "bolt in fit" so to speak.
I know a v1/v2 longblock/complete would be a direct swap without having to change anything, but would I be able to fit v3/4 v5/6 longblock over and just swap my inlet manifold over? Just wanting to know what my options are as far as direct swap of engine and/or manifold go. thanks! :)
Yea I would like to buy like a v3/4 v5/6 and hopefully just have only swap the intake manifold, the bolt pattern changed after 98 I think, but like you im not sure and the internet has so many answers that are not direct enough for me to put faith in. That v7 longblock with v1/2 heads thought, would v1/2 heads bolt on? and would I not need to change engine mounts or waterhose routes etc? that\'s a great alternative though
 titian said:
if you can swap the intake manifold. :) Engine will fit. If it is later version Loom/throttle body/ must be changed onto the "new" intake manifold ICV also requires sorting out. Easy. Done this a few times now.
Nice easy job. :D :D
Thanks titan,By "later version" does that mean any version past like v1-2 or post 98 models? ultimately Im going to ask someone in the Christchurch area who has a hoist and tools enough to do the job to help me install/swap in the engine for $200 or so, so the less work required the better, hence why im going to try stick to "in out" sorta job.
93-98 Phase 1 EJ20 DOHC heads have straight bolt pattern.
99-00 Phase 2 EJ20 DOHC heads have staggered bolt pattern.
so prehaps my options are a v1-v2 complete engine ($1600) from auto parts. a v1-v2 longblock ($1200) from auto parts, and swap my inletmanifold and turbo over. Or any longblock pre 99 and do the intake manifold and turbo swap over.
If I were you I\'d choose a V3/4 STI longblock or failing that an MY97-98 GTB longblock as the heads are much better. Mostly due to not having those horrible, troublesome hydraulic lifters in them. Although the V1-2 lifters aren\'t as bad as the earlier ones.
And then swap your intake and loom etc onto it.
 Zach']
Problem is If I go v3/4 sti longblock Ill have to do huge harness modifications
b]And then swap your intake and loom etc onto it.
[/b]
Nope coz you just bolt your manifold directly onto it so it uses all your sensors/TB etc.
What he said. ^^^^
