Fuel Regulator flow
funkytown
 soopersubaru said:
My opinion for what its worth:-
Two regs will never flow equally. End.
there was a reasonable conversation about this some time ago and its a good one to trawl through again :)
While i agree two regs might flow differently i take the inference that this is detrimental to the car as incorrect.
flow is one thing but pressure within a contained unit is another.
go.
I\'m going with funky on this one, if the pressure at the rail is the same on both sides then who gives a monkey\'s nut what the flow through the regulator is in order to maintain that pressure. Arguably the flow between them would always be different as they have to compensate for minute differences in injector pulse (and therefore flow) in a sequential injection setup.
I think what he was getting at was that the pressure between 2 will never be quite the same, even if you set both for 43psi or whatever. But surely the variance in injectors is similar to the variation between 2 good quality fuel regs, and I\'m sure you could tune around it and/or it wouldn\'t make three fifths of a damn worth of difference.
