link install costs involved?
QRAF
After my car not going for a number of day i started to suspect i fried my ecu so started to look for another one but that was easier said than done.
But i did find a link plug an play link and at the time i didn\'t want it as i thought my loom might of been the issue and didn\'t want to fry this one as well.
So long story short i got my car going and it wasn\'t the ecu but now i\'m thinking i should get that link as its a plug and play one so would just plug into my loom.
I\'m just wondering if anyone has had any experience with them before and whats the costs of getting it tuned and what not, I\'m in Hamilton
 evowrx said:
Million dollar question. Ring D-tech and get a deal on supplying/fitting/tuning worth the trip from what customers say.
He is on my list for when I get my link in.
Maybe I should just do it - instead of buying all this other stuff
If you get a plug and play one setup your IAT sensor, run the wires for it and then drive to the tuner on stock ECU.
Worst case scenario you wire the IAT in at there workshop, its a 2 min job and they tune. $1000 should get you a tune no issues and Tintins price above is awesome if you can get the same.
Oh also depending on the ECU you may need an extended loom to do an AFM delete, I had to get one but I cent remember exactly why.
Well it was a possum link didn\'t have the controller I guess that\'ll be a issue? Do I need anything extra with those will be in a better financial position tomorrow.
Or to I rebuild my adjustables man 21st century problems lol.
Could probably borrow a controller to tune it? They seem to get loaned out for a small fee from time to time.
Personally I would hold out for a G4, I only paid $800 for mine a few years ago, was a mint deal at the time but they do come up from time to time.
So i have a bh that Im converting to single turbo using a vf30 ,split fuel rail and yellow injectors with a 500hp pump, I have bought a G4+ atom and Im planning on using the map sensor that comes in the bbod,
http://www.clubsub.org.nz/forum/index.php/topic,41358.0.html diagram here
Im hoping the ecu can be wired into the existing loom, Im no electrican so I\'ll be looking for some one to do this, just looking to pick some brains at cost info as I am steadiy approaching the ecu intsall and tune phase of my single turbo conversion.
 broku420gtb']
BBOD-MAP/Wiring Diagrams on page 2:
[quote name='Rosssub said:
BBOD Wiring:
Solenoid: +/- Colour Code
ECV Duty Solenoid + Pink P
- Black B
Map Sensor + Pink P
- Green G
ecu signal White W
ECV Negative Pressure + Brown Br
- Brown Br
ECV Positive Pressure + Blue L
- Blue L
IACV Solenoid + White W
- White W
Supercharged Relief #1 + Pink P
- Pink P
Supercharged Relief #2 + Green G
- Green G
Map Vac Solenoid + Yellow Y
- Yellow Y
Pink is + from ECU
Green is Earth
White is Signal to ECU.
img]http://s28.postimg.org/3xqy0pc25/BBOD_Tests_009.jpg[/img]
ECU Pin Outs, for finding the corresponding Pins/Wires at the ECU:
http://www.clubsub.org.nz/forum/index.php/topic,6444.0.html
;D
