Bh5 gtb 1st problems
STiNGR
 STiNGR said:
My bh5 gtb won\'t select 1st... All other gears are fine but no matter how hard you push in the shifter it won\'t select 1st! Any idea why this is happening?
Syncro\'s jamming up inside the Box. Try getting first while rolling forward, might help it go in?
Edit: Also make sure the Bushes at the Base of the Gear Stick aren\'t warn out, might be too sloppy?
 Rosssub']
Tried doing the whole rolling thing. Still no love. It doesn\'t feel sloppy or anything. Will have a lol at shifter tomorrow.
 STiNGR']
what about when the engine is off?
..no matter how hard you push..
with gearboxes, no certainly does not mean harder. you can bend selector forks if you\'re too rough
 kamineko']
Na, tried with engine off. Doesn\'t want to select it at all.
 STiNGR']
[quote name='evowrx said:
Check ratios before you put the wrx box in as might need to swap diff also.
v4 STi going into my 1998 bh5 gtb...?
The sti box is likely 4.444 no idea on the BH box might pay to get the code off it and double check tho.
 JoKer said:
what condition is the clutch in? how is selecting reverse?
Selecting every other gear perfectly. Just not 1st. Maybe selector fork. How would I check that? Pull off shifter boot and have a look there?
Clutch is mint
1st and reverse getting tuff to select are "my" symptoms of worn clutch
only been thru two in the GTB (10+ years owning) so that\'s the limit of my input soz
ended up selecting 2nd then 1st (whilst stationary) made the job easier
unless you\'re having a hard time while selecting 1st while moving? [not recommended, 1st has no syncro\'s]
 JoKer']
sorry Jared, irrelevant due to:
doubt its the linkage but could be bent selector fork or damaged syncro
also,
but it does?
Clutch is fine, if that was shagged there would be no way I can start in 2nd which I had to do today
Reverse is fine
2nd,3rd,4th,5th all fine
Tried 2nd then to 1st, no luck
Was absolutely fine yesterday, driving fine, selecting all gears with no trouble. Stop at a set of lights. Wouldn\'t pick up 1st, hasn\'t since.
 Rosssub said:
Should be straight. That would stop the Select Lever Going right Forwards for 1st Gear.
Hopefully that\'s all it is...But could be the result of trying to force it.
Edit:
Ok... I wasn\'t forcing the shit out of it. Just reasonable pressure to see if it would engage. Are they a replaceable part or do they come as a unit per your pic?
