High Octane or Normal Octane?
Hello,
I have recently purchased a 2002 Impreza (Not tubro) and will need to fill it up soon, the guy who did the pre-purchase inspection said all Subaru's need high octane however I have read otherwise. What do you think, will I need premium or just stick to normal?
Thanks!
 eZ_Harry said:
Is it bad if the car has some 91 in it and I then fill it up with 95, so there is some mixing?
Na mate not a problem. Try use as much of the 91 as possible then fill up as much as you can with 95. You'll be sweet
Ran an old n/a bg7 on 91 foryears. Never had an issue. Except the time the crank pulley bolt snapped in the block when we did the cambelt... but that had nothing to do with the fuel.
