Coolant hoses.
Percy
So, I've been looking for some silicone ancillary hose kits for my Rev C GTB of Deth, and the options are either very expensive or non-existent.
However there are kits available for every model WRX under the sun sea or moon.
Do any of youse guru's know if all or most of the hoses from a particular model WRX kit would fit?:confused:
Also note the different angle at the block for the top radiator hose. Rev A-C has an angled alloy crossover pipe but Rev D-E has the straight forward facing crossover pipe. So the wrong model hose will be slightly kinked.
Rev D/E and version 7+ on the bottom:
The blue kit linked above is for a version 7. So as above the top radiator hose will be slightly kinked on a rev A/B/C. Also the turbo coolant hoses between the turbo's and header tank wont be right, the TT has a T piece in the secondary hose that feeds off to the primary turbo (10mm and 12mm). Also one of the firewall heater hoses will be wrong WRX-TT, because both TT heater hoses are together under the TMIC.
Roger!
I knew about the turbo hoses being wrong, so they will have to be hacked a bit.
Might get one of the cheap ones and report what fits and what doesn't.:)
Also now there is both a Rev C GTB(mine) and a Rev D RSK (Kims) in teh family, can report on the differences between fitting the kit to both!
Dammit, that's a lot of faffing with hoses, and a lot of coolant...:confused:
And probably some bleeding, there's always bleeding.:rolleyes:
