What sort of injectors should I buy? 1991 rs legacy with td05
slystiguy
So as per the title I'm looking for a set of injectors...
There are so many options here I really don't know where to start
Firstly my engine
ej207 sti block
ej20k sti heads
intercooler+exhaust
currently stock grey injectors with split rails
td05 turbo on 13psi
So my estimation of max power is around the 220kw mark with the td05 maxing out around this point. Dunno what the block would be capable of.
Anyways what size minimum should I aim for? I was thinking 700cc would be smallest I'd go for but do I really even need to go that big?
The other options is converting to a top feed setup... What are the advantages of doing top feed over side feed?
I'm also open to suggestions on where to buy from.
DSRturbos can sell a 1000cc top feed set for $419 + rails setup costs which adds up to around 600-700 by the time you get fittings ect.
Alternately I see on ebay I can get a set starting around $350 for 550cc and add about $50 every 100cc
What is everyones thoughts?
Minimum size?
Top feed yes or no?
Where to get cheap large side feeds?
Here's a pic of my current bay setup for some attention hur hur hur :) (still a work in progress)
I got just on 200kw from standard ver3 yellows (440cc) and a td05 on about 19psi
You can get later model yellows decapped, I'm currently getting a set done and tuned for my car, they flow just on 800cc.
talk to tony at Dtech in tauranga, he's doing my injectors for me
 Leufkax said:
Wildturkey uses Silvia side feeds, go straight into the stock rail. Think they're 475cc or something, his BC5 pushed 226kw on a dyno with the same setup
Lol yellows are 440cc f all in it. If early v1/2 mani could use later side feeds 550cc or whatever they are the blue legy ones.
