car won't start running v8 sti with g4+
arnegs
 Koom said:
Have you run the tests within the ecu to check for spark on each of the individual cylinders?
Checked the timing with a timing light?
It only gives me the option to test igniton #1 and #2. And when we tested which was which and #1 was plug 1 and #2 was plug 4..20151019_203757_zpsy7jww7ap.jpg I'm only new to this so I'm learning. Cheers
Guessing you've changed the G4+ ignition mode from direct spark to wasted spark, that's why you can only test ignition 1/ignition 2. So ignition #1 will be cylinder 1&2, then ignition #2 will be cylinder 3&4.
Is it a plug in or wire in G4+? Are you using a version 8 STI loom from engine to ECU?
Also shouldn't AI4 be set to AC fan, rather than Engine Fan 3?
 boon said:
2:17am, wifey got you sleeping on the couch again?
Haha no, first night without our kids so movies in bed till late cause Clint has my birthday week off work
