righto fulleas and fulleasses this is how a lazy shart gets the cat out a primary dp .
the engine was out of the car and this whole exercise took less than half an hour
step one . grind through the crappy lil welds holding the bottom heat sheild on
step 2 chop a square hole
select an impliment
introduce chosen impliment to cat internals .bash it right through . ream it round a bit . pull it out . bash it through on an angle . repeat a few times . once youve been through it a few times it will break up into chunks . can smash most of it up by hand
might need to give it a bash and a shake . comes out pretty easy
keep going untill it stops rattling much . and untill you get these 3 bits of mesh out .
much better
weld your square back in
weld the heat sheild back on with 5 little ****ty bits of weld
yeah there are easier ways to do this or more professional ways . getting a piece of pipe suitable is difficult and actually getting it to fit requires a few goes at tacking it and being under the car etc . this you can do on the driveways in your jandles and be guranteed it will fit back on exactly like it was . this literally took half an hour and ten minutes of that was fixing the welder
i think i did this once for a single turbo dp aswell . to be honest you are better off cutting the side out of the cat pulling the cat guts out and welding the side back on and its fkn hard/takes longer to smash right through the 2 cores in a single dp. then u can take the cat core to the scrappys for $30
if u need to replace a primary turbo then its the prefect time to do this . and replace the turbo to intercooler hoses at the same time . will literally make it feel like a new car
Good stuff, joining the rangi decat crew. Aren't the TT ones a splitable downpipe like some of the newer non TT ones? Mine just had a flange halfway that meant I could split it and just use a hole saw to drill 90% of it out.
nah the secondary down pipe has a join in it . but no cat . the primary downpipe is one piece from turbo to a bolt on flange right at the merge .
or are you talking about the main cat ? right after the merge ? yeah u can jus unbolt right next to that and bash it out
i really dont think this cat is doing much after 20 years and 200000 kays . well it restricts the exhaust and the noise but thats no use
Na was talking about the first one. Seems way blacker than mine did too, either they used a different material composition back then or yours is just way more clogged than mine was.
I just added 25% ($150) To the budget for this car . Thats for two vf27s and a broken vf26 ...
Also fk me the ecv is an ugly pos . Like in erry way . When I get a rev d im swapping it for a butterfly like a supra
The 2nd cat is easy to replace with a pipe . The primary cat is a pain coz it needs a bend and is in a difficult place to mock up etc .
I only do it this way coz its easy and its gunna fit perfectly
Id do it and see how u get on . If its a problem try change some restrictors . After that drill the wastegate hole out . The vf13 waste gate hole is fkn tiny . Like 13 mm . The vf26 waste gate hole is bigger .
