Kol12's not quite right B4
Kol12
 Kol12 said:
Is there a way to get the 2nd to kick earlier? I'll have to check my engine bay tmrw.
I probably should look at sticking a boost gauge on. Is gauge only really any good for determining how well the turbos are functioning?
Well its telling you what pressure the ntake manifold is seeing. If you know what it normally sits at then you know when somethings wrong. I don't think you'll find anyone on here who would think getting one is a bad idea.
For what you're describing you really do want to have some accurate numbers and not just guestimates to confirm whats happening
 Kol12 said:
I'm just not getting much of a kick from the second these days, I don't think I need a gauge to know that.
Yup I'll just fish out the Subaru Service Manual for this model and look up "not getting much of a kick from the second turbo"
Because that is a diagnostic term.
Ok, possible things:
-Bad plugs
-Bad fuel
-ECU going sad
-Bad injectors
-Dirty injectors
-Bad coil
-Low voltage
-Coolant temperature sensor
-Cam position sensor
-Blocked cat
-Collapsed muffler
-Pre-turbo exhaust leak
-Exhaust oxygen sensor
-Primary turbo failure
-Secondary turbo failure
-Vaccuum leak
-Stuck/bad solenoid in BBOD
-Exhaust actuator diaphragm leak
-Seized actuator
-Head gasket
-Piston failure
EDIT:
-Fuel pump
-Fuel filter
-Fuel pressure regulator
-Knock sensor
Mmm check all of those and see if it fixes it.
Edited by boon
Have you ever watched a dog chase a lazer dot
I'm getting deja vu here
Take it to a garage, otherwise you're literally replacing non - expendable parts to remedy a problem that may not even exist
Simplest way to make your car feel fast again is drive something underpowered for a fortnight
