Diff-icult situation
Andy_Mac
So was under the car doing the sways, noticed the diff plug had a bit of oil round it and decided to give it a bit of a tighten. As my luck would guarantee, pretty much the second It started moving it got a whole lot looser and the thread is now royally stuffed.
Anyone done something this dumb before? Don't think I can get the diff rear cover off with lowering it down. And think it may be a bit hard getting all fillings out if a tap is used whilst still on the car.
Would prwfer to not have to lower it but if thats the only way then i'll have to give it a crack
Na not a clue yet. If i drill the old thread clean out i'd need a 20mm drill bit, so guess that corresponds to a 20mm tap?
Thought about thread tape but would rather do things right and not have to worry about it failing.
Edited by Andy_Mac
Having now drained it and pulled the bolt out I can see the bolt is super short and has only ravaged half the length of thread. Happened to have a spare top plug which is quite a bit longer than the bottom for some reason so gave it a decent amount of thread tape and chucked her in, hoping the remaining thread will do its thing
And these have 180's so don't imagine 2nd hand covers are quite as common or as cheap.
