up pipe turbo studs rusted... who can repair ASAP in WGTN?
loner
It's not a stock up pipe. Anyway it seems I was over reacting a bit. After running a die over the two worst studs and using
new nuts... they hold ok. The other two weren't bad really.
Anyway a pic to show current state of engine bay... nearly finished.
I don't post much cheeky **** anyway... just on special occasions. Turbo is a TD06 hybrid... I know not much more than
that. Seems to be decent quality, receipt said $1600, so should be okay. Originally it had a Garret GT3082, but the previous
owner claims that this one spools better and should reach similar power levels. I suspect he changed it because the last
one was damaged in a fire. He never mentioned the fire funnily enough, dirty Timaru sheep ****er.
Glad you got it sorted. You know of the standard trick with replacing those studs? Wind 2 nuts on and use open end spanner to turn the the lower nut which turns the stud out. Probably wouldn't be too keen to re-use damaged studs personally. They're not in a favourable spot for removal if they decide to weld to your nut haha. Or else standard removal process of grind and drill/easy out/ re-tap new thread and stud. I've done both before neither is fun. I've also used a chisel to smash off nuts, that was a massive pita hahah.
Those turbo care guys did a great job on my td05. Frekn expensive in comparison to other shops though.
