Holset discussion
 chulozumo said:
Hahahaha good thread, cheers.
How much better is twin scroll vs single scroll for a holset? I know TS is better but by how much? Just trying to decide if I should ditch the single scroll
been my issue for the last year... but im ditching single when i go big turbo. Gotasuby has had mad results from twin-scroll hx35 on a 2.5L.... 27psi by 2700rpm or something. The possibility to run more boost, on a bigger turbo and still spool fast is awesome, not sure how much more lag a 2.0L will have though...
Are holsets just a **** load of work to get setup or something? Really expensive? Pretty green as to what can do what in the world of turbo's
If they're capable of spooling that early why would you ever bother going to the effort of twist mounting something else?
holset is life :P from what i gather... they are cheaper than garret, thats my limited input
Edited by hunter951
I can attest to the fact they are clucking big and heavy to try and fit in a wrx engine bay. Cheap turbo 1.8k for a murch hrc or 500 odd for used ex states. Ill update my other thread as i go see if can standardise the parts reqd somewhat.
