99 GTB Fuel Consumption?
iludez
Using 2 tanks a week then? Maybe a touch more?
Yep a tad more.
A lot of it is running kids from school kindy etc. But then we are 15khs out of town too. So maybe I'm just being unreasonable in the mileage as it is quite a lot. But thought it would be a bit better?
I'm thinking maf might need a clean?
I would say it's fair. It's a performance AWD wagon that's also pre AF sensor, ie it's got a narrow band front O2 sensor rather than the later wideband air/fuel ratio sensor. Yeah try a MAF clean, can't hurt. You're probably better off chucking a brick under the accelerator pedal though.
Being a twin turbo with a pea size primary turbo it will always be on boost, especially with around town driving.
Make sure the plugs are fresh, MAF is clean, thermostat is working and all that good stuff.....and you could also let off the jandal a bit, but who wants to do that ;)
'round town I typically get about 11.5l/100km.  So about 450km before the light comes on and I refill (~48-50l)
It'll rise drastically with a heavy foot, or go as low as 9 cruising on the highway.
This is a RevB 208 in a short-ish geared BH outback.
Secret is to try to keep it off boost.  Its definitely an art of twitching your toe rather than using the foot.
