Is low the new rotated?
Gripless
Pro's
Less heat loss
less pipe total for exhaust and intercooler
Longer straight from turbo
option to make heaps of room moving radiator
cooler and more airflow over turbo itself
Con's
custom pipes required
new radiator and intercooler
rotated intake preferred
oil lines
Not the norm
Massively annoying Cons
Oil feed and lines
return system since likely below the oil level in the sump (see box for brz below)
possible dry sumping
Tuspeed low mount turbo pipe kit.
ok o it costs way to much but otherwise all the goodness.
GTX35's, GTX40's and EFR8374
AVO BRZ unequal length option for that rumble everyone loves.
Just as an example as guess FA has different spacing on manifold. Does anyone know if the FA is that different, i.e. Can you just use the current sti headers.
AVO-Turboworld-turbo-kit-for-Subaru-BRZ.
Edited by Gripless
Make boon happy
There’s a few Aussie Legacy’s running them, heaps of work to get it fitting snuggly.
Looking at the small print for that Tuspeed one it needs the Processwest V mount intercooler which won’t come cheap, on top of an already hideously expensive setup.
There was actually a US guy doing pretty well at sorting his own but gave up due to cost sadly.
http://legacygt.com/forums/showthread.php/low-mount-twinscroll-turbo-concept-ej25-250104.html
Are BRZ’s further back and lower or just lower?
Yeah I read the process west bit, but I don't think you have to use them just its the easiest option.
wow he went to town on that collector, not sure why he is crossing the headers over.
i like the twin scroll cut off plate from the supra guy, but I've think they have it a little wrong.
I'd have it hinged one side and mounted in the center of the twin scroll flange so when:
open it allows the second scroll and separates the two halves of the manifold so the flow isn't messed up like adding the plate to a single scroll flange.
closed it stops the second scroll, but opens a path for the two halves of the headers to flow through the one side.
Edited by Gripless
Can't spell
10 minutes ago, boon said:
I don't think  "cons: oil lines" really does justice to what's required to make a low mount turbo not S*** oil through the seals constantly.
Yeah that little box kinda give away the extent they had to go through for the brz.
I'll fix the first post for you...
fixed ;)
still not not sure it put off the idea, yet.
Edited by Gripless
