DIY Prevention
Couldn't agree more, insure it, alarm it and take all the precautions you can.
Unfortunately if someone who knows what they are doing decides they really want your baby they'll likely get it. You just have to make it as unappealing as possible, like putting Jessica Biel in a gorilla suit.
  • Replies 82
 Old Skool Subbie']
[quote name='Bjcnz said:
I've got it solved for those that don't like the brake method there's this way - url]
[/url]
haha I like one of thoses :P:D
c
classic
haha well yea, the angriest meanest looking one does, its actually the biggest softy of the three, food is the mighty staffys major weakness, then again if they knew you were up to no good they would probly take the food from you and then proceed to eat your hand/face/other bodypart
Take off all the designated tow points!
No tow truck will have its way with your pride and joy then.. ::)
*sarcasm inserted.
Seriously though, whats the easiest way of getting a car onto a flatbed?
I haven't a clue, but if you can answer this, then maybe you can make it slightly harder..
Most flatbeds have a base which extends out and sits flat on the ground... push the car on, put some strops thru the wheel spokes / around a subframe / whatever, to secure it... then push the button and the bed pulls itself back up.
Easiest solution, keep your car on a REALLY BIG fully armored tow truck with super high security, that nobody else can put on a bigger tow truck!
I still think one of the best defences is your drive way. With ours, it's possible to park one of the cars in a way that it is literally impossible to get out without it's own power. Unless you rigged up a pulley system or had literally about 6-8 bro's push it up the hill (they'd be on grass too). The only way to get the car down the drive is to drive up into the carport, then reverse out and back down the drive. My bedroom is right above the car port, and my 3" has no problem waking me up.
Even when not parked in that sweet spot, it's still a woefully bad drive. The only obvious attempt at a car theft that has happened here was several years ago when someone tried taking my brothers lazer wagon. We found it in the moning stuck, wedged in the narrow drive diagonally. They failed to manouver it enough to get it straight down the drive, and once stuck, it's stuck, it's like a 30º incline! Only way out is under it's own power :D
