Trying to decide on the best way to wire up the primary in-tank AEM 340lph pump and the surge tank Bosch 044 pump.
I currently have full aftermarket power supply setup with circuit breaker, relay feeding into a fuelpro pump speed controller that I'm not sure what to use on.
Options would be
A) Leave the current factory speed controlled supply setup going to the in-tank pump which should be ok with the lower amp draw once it is running as a low-pressure circulation pump and hardwire the 044.
B) Hardwire the in-tank pump and use the aftermarket speed control setup on the surge tank pump assuming they are happy with lower voltages.
C)Hardwire both
D) Factory speed control the in-tank pump with the factory setup and speed control the surge tank pump using the aftermarket system.
