Seemed to developed a slight boost issue with my forester xt 4eat
Can hear the turbo spooling but sitting at say 90kmh and go to pull out and pass the turbo initially boosts but drops off a small amount before coming back on full boost does it at about 4000rpm
Won't do it from standstill when u boot it
Car is stock apart from a perrin turbo inlet tube
Any ideas it's not hugely noticeable but still annoying, kinda feels like the gap u get in the twin turbo legacys
9 hours ago, Loren said:
I'd check the plugs and leads.
Just had new plugs not long ago and replaced 1 new coil hopefully the others are still ok
What gap did you set?
So coil on plugin is it?
It sounds a bit like it could be mis-firing from what you have described. 4000 rpm is where the boost will be coming on very quickly, so peak torque... possible over boosting a bit and the spark is breaking down. Though I'm not sure how likely that is with coil on plugin.
Edited by Loren
Yep coils, I never touch the spark gap when doing plugs ...
Interesting it's very slight and not violent boost drop, could be the coils as it's done high kms now - 240kms
