Long story short this is how to get the fault codes from the abs on my jdm v3 sti gc8
Theres a heap of info on the net but none of it was the same as mine
Step 1 . Find the 2 earth prongs hidden inside tape in the same tape around where the wires for the green n black diagnostic plugs comes from
They are black.  And sheathed individually about 3mm round . They are folded back over on them shelves and taped up from factory.  Mine had blue tape.
Step 2 find this black 2 pin plug that is smaller than the green n black plugs .
Jam an earth pin in the blue n white wire . (Nothing happened when i tried the other wire )
Turn key on . Abs light will give you the 10s n 1s for a code .
It can only store 3 codes even if you have more
Jamming the earth pin in and out at least 3 times clears codes .
My only re occurring code was 52
Under the motor on the abs pump where the cam actually drives the 2 plungers was bit rusty / crud .
Wd40 n a dung out and some grease on the faces it was good as again
The top cover and magnets come off the whole thing with no fuss . The 2x torx 25 you can see .
The rotor n brushed n next plate didnt want to come out but that's only because its sealed/glued into the alloy housing . A small tire lever against the rotor broke that glue
Codes:
Abnormal ABS sensor, open circuit or voltage too high
21 – front right ABS sensor
23 – front left ABS sensor
25 – rear right ABS sensor
27 – rear left ABS sensor
Abnormal ABS sensor, abnormal ABS sensor signal
22 – front right ABS sensor
24 – front left ABS sensor
26 – rear right ABS sensor
28 – rear left ABS sensor
29 – any one of four
Abnormal solenoid valve circuits in ABS control module and hydraulic unit
31 – Front right inlet valve
32 – Front right outlet valve
33 – Front left inlet valve
34 – Front left outlet valve
35 – Rear right inlet valve
36 – Rear right outlet valve
37 – Rear left inlet valve
38 – Rear left outlet valve
41 – Abnormal ABS control module
42 – Source voltage is abnormal
44 – A combination of AT control abnormal
51 – Abnormal valve relay
52 – Abnormal motor and/or motor relay
54 – Abnormal stop light switch
56 – Abnormal G sensor output voltage
Well there was going to be a bonus pic of my car also . Now noone gets any pictures because I cbf making them less than 200kb right now.
Where are you lot hosting pictures now ?
  • Similar Content
    574.7k
