I installed a steering wheel control adapter and was able to map the volume and track buttons to the aftermarket radio but the rest of the buttons are not being detected. Can anyone recommend someone who can have a look and possibly fix it? Thanks!
If you're not up for it yourself any car audio shop should be able to sort it.
By adaptor is it just an adaptor cable or one of the interpreter boxes?
I had some trouble with mine not sensing the resistance differences well so I ended up using an interpreter box as well which definitely helped but I had to run my own cables as they weren't there from factory which I assumed was where the issue was
Thanks for the reply. I have a connects2 steering wheel adapter. Can you recommend car audio shops in the Auckland area that may be able to look at it? Thanks!
Nah not really, I'm not based up there but it shouldn't be too hard for any shop up there
    574.7k
