There are ducted shrouds and splitters from the scoop to the top of the intercooler, but nothing after to direct airflow!
Older models had only a small vent to bypass the intercooler to feed the turbo cooling duct. Which was fine as air only exited under the car.
The newer cars have a large gridded vent on each side as well as a series of rectangle cutout along the back of the seal.
Im guessing they have these to blow the hot air to the sides of the engine bay and out via the front fenders and vents. Though possible that the side without the turbo needs far less.
The rear rectangular holes would have sent external air down the firewall and over the clutch master etc.
This also lets the hot air vent back through the scoop when not moving. The large gridded vents are the highest point in the engine bay so convection does its job. It is very noticeable on cold of rainy days when the shimmer from the heat exits the vent in standstill traffic.
Now with a large intercooler fitted the duct ends 4cm from the back edge of the fins in the core. The much larger inlet takes up almost all the gap to the firewall. So any air that vents back there is above the seam to the wiper motor area and won’t flow downwards over the firewall.
Since this requires the OEM rubber duct to be moved 4cm or more rear wards just to cover the core, maybe there needs to be a few deflectors underneath to direct some of the air towards the firewall. This may also help direct more hot air to exit under the car rather than become stagnant near the firewall.
