Hi Team.
I'm on the hunt for an old ABS Pump as mine is leaking at the join.
it is a old legacy style with the part number 27531AC000.
if anyone is able to shed any light, that would be greatly appreciated
thanks a million.
I had a bit of a look, but you’d need to check the pump physically matches as I don’t know much about Subaru parts and just following part numbers.
I’m guessing this is old style abs with ecu and sensors attached to the pump?
Anyway this may help…
27531AC000 has revision 010,020,030 then 03a then 040 and at 27531AC04A it jumps over to superseded 27539AC04A for 1999-2001 2.2L 2.5l legacy and forester
there’s a 050,060 and ends with 27539AC06A
last model on amayama
https://www.amayama.com/en/part/subaru/27531ac040
from there it seems to go to the forester code with 27539FC010 seeming to be the most common number for 1999-2002 with some places selling it as 1997-2003.
that has revisions 020,030,040
Only model on amayama
https://www.amayama.com/en/part/subaru/27539fc010
Edited by Gripless
    574.7k
