O2 sensor on downpipe
 driftrex said:
it'll run but ideally you want it hooked up, just get a threaded port and have it welded to whatever downpipe you end up buying, exhaust shop will be able to do that for you..
The O2 sensor (or lambda sensor as they call it in some places) helps the ECU "learn" and fine tune the fuel mixture. Especially since you're looking into aftermarket and subsequently larger down pipes I'd highly recommend you get it fitted so the ECU can compensate for the changes! If you're around The Shore (i.e. Auckland, North Shore) I can grab the contact details of the guy I got to tap a hole into the bolt on my aftermarket pipe so that the O2 sensor would fit on, otherwise as driftrex said exhaust shops and plenty of metal work shops can get this done, hope this helps! ;)
but you can run without it as i had for about 6months it just runs rich driving around town but i seemed to get more km's out of a tank on longer trips though. :-\
but yeah its recommend to have it installed or i'm sure they wouldn't of put it there.
