Been collecting all this stuff onto my hard drive. I even made my own pinout for the pre-face-lift BE/BH's.
So here's the ever illusive BH pinouts. Caution, it's still a work in progress
BH5A Turbo Pinout - WORK IN PROGRESS
And some handy stuff:
MY99 Legacy Wiring Diagram. Turbo models included!
http://reuben.xpjets.com/random/BH-Conversion/BH-WiringDiagram-JDM.pdf
V5/6 Wiring diagram and pinout
http://reuben.xpjets.com/random/BH-Conversion/Possumlink-MY99Manual.pdf
Legacy pins vs Impreza pins. The top is legacy, bottom is Impreza. Note the pin numbers, B134, and B136 are reversed on the 2.
Factory legacy pinouts, awaiting proper scans
  • 8 years later...
Almost 10 years later, I'm hunting the internet high and low for DAYS trying to find a BH5A twin turbo pinout to diagnose a no start... and google leads me right here! Thank F*** I uploaded these, cause 3 or 4 computers later, they are gone from my hard drive!
Anyone have the complete A-C rev BH5 turbo service manual? I can only find D-rev AUDM complete, or A rev USDM N/A...
Anyway, I've re-archived these on my google drive, I ought to make a public drive for posterity.
As bout as many members as you'd expect from a small population of 30k or so! Mostly offline subie mates rather than forum goers though. We had a pretty strong contingent for flatnats, something like 8 cars! Not bad.
Hi Reuben i was hoping that some one might be able to help me out with my conversion.
i have a 97 BG5 that ive recently converted to single turbo following this guide.
all the parts i used came from a 97 forester retaining the Ej20r and just using manifolds and what not from the forester.
I have a version 4 "75" ecu also running the single coil pack on the intake manifold.
I've wired the ecu and igniter as per this guide and i have no spark. ive tested the coil pack using a multi meter and that all seems fine.
my understanding of the wiring is
at the Ecu A9 is wired in to A10
A22 and 23 are wired in to A9
B18 is ground.
the igniter is ground
red and blue wires to the coil pack
and the 2 triggers to what A9 and A10 respectively
the car cranks but has no spark.
12v power is at the coil
have i misunderstood the wiring from this guide?
Thanks in advance
