Had my clutch done today. I get it back and notice its got loud flutter under WOT and high boost. This is not Flutter when lifting off, but under WOT.
I'm picking possibly a leaking intercooler hose? or some other kind of vacum leak?
any ideas?
 BigWillieStyles said:
Do you have an aftermarket BOV?
Factory BOV's. Tried swapping them around, but taht didnt work.
Yeah. I'm holding full boost, and there's a distinct sound of air accompianing the flutter when the windows down.
BOV's have been checked, and swapped over (primary is now on secondary and vice versa)
Having driven the car a bit more now, it seems to be intermittant. When the window is up, you can faintly hear it adn its coming from in front of the front passenger seat.
After reading a bit more now, i think its wastegate flutter. But i am no closer to knowing whats causing it.
The reason the clutch was mentioned is that it was OK before going in to get that done.
Edit: When the windows down, It sounds almost like a plastic supermarket bag is caught under the car and is flapping rythmically.
same sound as i friends wrx that has a T in the waste gate hose (rangi way of a few more psi) to much boost in his case 1.3bar.
You got a boost gauge?
 keltik said:
$20 says its an exhaust leak somewhere near the turbo. My old GT did the same thing.....never did fix it tho
Bang on. Y pipe had to be removed to remove the box, so when i crawled under the car today, first thing i saw was a bolt missing from the flexi join right in front of the cat.
Sorted!!
Cheers.
You fixed it?
I love compressor surge flutter!
You fixed it?
Yep fixed! and it wasn't compressure surge (had that in the WRX)
Twas one of the spring loaded bolts on the Y pipe/Cat flange was loose and then missing!
    574.7k
