Rocker gaskets arhhgg!!
Ryan
 Ryan said:
Whats the secret to getting rocker gaskets to seal properly? They seem to always bloody leak, even after I put Loctite flange sealant on it.
Doing it like the manual says? Add some gasket glue in certain parts
And also replace those washer to ensure you get a good seal, (yes they are like 7 bucks each :o )
and only use genuine rocker cover seals
Hmm maybe aftermarket is my problem then, used the ones that came with my top end gasket kit. Would the original ones work if I used gasket sealant (i think they're original, at least they didn't leak) or would they be too screwed? Kinda need it fixed urgently, otherwise yep it'll have to be original.
 SPANKU said:
where is it leaking from? what part of the cover?
Mostly from the spark plug rocker seals.
Dunno, but i got a nearly full tube of three-bond here, plenty to go around.
Do get genuine parts, and get the little washers, and the half moons too. I didn't get the half moons when i did mine, and they later cracked and leaked. Had to re-do the seals all over again...
I pulled out the old (non-genuine) gaskets and compared them to the original genuine ones, the aftermarket are much thicker to the point where they squash out the side when you bolt the covers down. I put the old genuine ones back in with lots of Grey Maxx and they're mint now. By the way, rocker covers can be done with the engine still in the car, just undo engine mount nuts and lift up each side of engine.
Thats great, but who the hell ever said you had to take the engine out to do rocker cover gaskets. You don't even have to undo engine mounts or lift the engine. I have done them in-situ, without any problems at all.
If i was to do a major service on my car (i.e - spark plugs, cam seals, rocker cover gaskets eg the works), and had the use of the engine crane i'd pull the engine out as its a pretty simple 1 hour out, 1 hours back in job... and would make life so much easier
if it was a minor service, i just leave the thing in...
 Shale said:
It's something a lot of anti-Subaru knobs like to pass around - that they suck because you have to yank the engine to do anything :P 'Spark plugs' is the one that they always drag out!
It sucks how subarus have that stigma. My inlaw's mechanic hates them and takes pleasure in telling the mother inlaw how un-reliable they are, which then transfers to my other half. It has taken about 8 subarus over 5 years without any major problems (we'll forget to mention the third gear failure in my last one) to prove him wrong.
I believe it is a measure of a descent mechanic; asking him what he thinks of subarus. A mechanic that has the aptitude to work on something that is a bit different without complaining, in my experience, is likely to be a good one.
What I usually say to nay sayers is: have you tried doing a cam-belt or replacing the back 3 spark plugs on a v6 vr4 lately?
Guest itsgotgo
hell i have done them without doing the engine mounts.
I have neanderthol hands too!
Its all about the way you hold your tounge :D
 Treecrusher']
Hell even doing a cambelt on a corolla,1st thing to remove is an engine mount and i am Like WTF
 DRFVDR']
Or a waterpump on a RAV4 with ABS. The f'n ABS pump has to come out!! >:(
Subbies are easy. Its just a pity big ends are so common.
