Rocker cover gaskets?
As title states, how much am I looking at for replacement for both sides?
Is it a easy DIY? If so could someone post a How to :)
Thanks
ya can change them yaself . ive been told it involves unbolting engine mounts an raising engine slightly.
drain ya oil for a while . unbolt and catch the drips . clean!!!!! . new gaskets on . also been told to put rtv on the groves at the frount of heads and on the back where theres the inserts in the head. dont no weather any1 else agrees on the rtv but i did it to mine.
Yip easy as to do with motor still in car... remove obstacles: airbox/pod filter on left, battery/waterspray bottle on right, spark plug leads/coil packs on older models
Pop 6x 10mm bolts off and covers should pop off easily with a gentle pry
Replace the 6 rubber washer things at the same time as they sometimes leak/seep too
A bit of gasket glue on the half moon thingys and near the oil seals doesn't hurt either - not too much that it'll go back into the motor with covers in place
of course i cheated and done this with the motor out, but you get the general idea...
I just did mine a few weeks back, easily done without unbolting the engine mounts, I just used a mirror on a stick to make sure I got the old gasket goo off properly.
Parts were about $130 from subaru, good luck if you try buying aftermarket as there are about 16 different types of gasket.
Make sure you replace ALL of the seals that go on the bolts, they shrink over time and this is what causes the covers to wander and break the seal.
Guest sleeperfoz
be sure to clean the surface that the gaskets are going onto.
so there is no oil or residue left .
one of the biggest causes of leakage after replacement,
do not over tighten bolts :)
  • 3 weeks later...
