V7 manifold
pl0x
rangi mod (warning) :D
1 - cut in the middle of a strait thru spacer off an sti (or clean the wrx tumble valve thing)
2 - get a silcone pipe that can slip over the 2 ends and cut height to measure
3 - install - maybe add some stel brackets to support weight if needed
so in very bad graphic form:
1 - normally
2 - cut here
<snip or equvalent>
3 - join tightly with tight fitting silcone pipe made to height
| | the tight silicone pipe
4 - wallah height adjustment made!! (add brace made to height if needed - recomended)
see done!!
:D
end of Rangi Mod lesson
