Suspension creaking - any ideas?
Flat4
I've been hearing an annoying creaking noise from the front of my Legacy when going over bumps - speed bumps, driveways and other bumps in the road.
Had the mechanic look at it but didn't notice the noise even after taking it for 2 drives. He removed and re-lubed sway bar d bushes, but it hasn't made any difference.
Made a quick vid this morning going over some speed bumps:
Any ideas on where this might be coming from?
If your using nolathane, a dry control arm bush makes this noise. Only take 15 mins to whip them out and re-grease. Dry sway bar bushes can also creak a bit going over speed bumps, also easy to pop off and grease.
 pl0x said:
i have a similar problem,
my front struts crack/creak when moving at low speeds or not moving at all, when turning side to side. easiest to hear when you first start turning/moving
this lanolin spray should fix this?
Might that be the top hat bearings?
I think your mechanic needs a hearing aid!!!
