are these legal? or do i need a cert for them?
It pays to keep an eye on the cerification thresholds as they like to change stuff every once in a while. Especially if someone tells you that you can't do something.
LVVTA.org.nz
What they say goes ;)
I've just read this as well.
Was surprised to see that any turbo substitution or ECU modifications require cert.
Good thing most WOF guys don't know what size turbos come on our cars, otherwise it could make the vf22 swap a bit difficult.
Or am I interpreting that bit wrong.
I beleive it only applies to non-oem modifications.
 wrx_lou']
so does that includes ECU chips???
 smokn4']
On the second to last page it specifically says cert is required for turbo cars.
Seems a bit un-fair considering some v-tec hondas put down similar power and could equally benefit from an ECU chip.
 smokn4']
[quote name='wrx_lou said:
IIRC you dont need to be certed if your increase is within a certain percentage of the factory power rating.
yea thought it was only if you increase power by 30% or more
20%.
But as mentioned there is the note stating that "Certification is Always require for the fitting of a supercharger or turbocharger as a modification, or the substitution of a turbocharger or wastegate, or the re-chipping of ECU's in turbo cars."
So you are supposed to get a cert even if you swap your vf23 for a vf24.....
 Koom']
20%.
So whats the go when a 250T has a Ej20tt as an engine swap? because its not a a turbo being fitted "as a modification"?
 caged']
20%.
Fitting a turbo engine into a previously non-turbo powered chassis is a modification.
Requires a cert. And a hoop around the driveshaft. Read the whole pdf.
