Have EJ16. What do?
so basically i have all the old running gear from the 1.6 Auto. the engine looks like i needs a new crank seal and belt, but otherwise ok.
should i sell as is
should i repair the seals, clean it up and sell
or ?? ??
then profit?!
kinda tempted to throw it all back into the bent RA shell to create a weird-as runabout. but i think straightening that car alone would cost 2-3k
hmmmm
thinking pull it apart, practice/learn to port the heads and slap on a primary from an old TT
forced induction (low boost no i/c) + quad throttles do sound fun tho
there must be some small enough throttles at a wreckers that could be botched to work.
EJ20 turbo extractors fit EJ16?
Guest lan_killa
Could get some quad throttles off a toyota 4AGE, but they dont come up terribly often and everyone is looking for them... or for pure awesomeness chuck a pair of side draught webbers onto it with some velocity stacks on em, the right ones will handle some boost (8psi ish).
Depends if you want to go the injected or carby route
There's two sets of quad throttles on tardme for ~$120 ;)
http://www.trademe.co.nz/Browse/SearchResults.aspx?&searchType=0001-0877-&searchString=quad+throttle+bodies&x=0&y=0&searchregion=100&type=Search&sort_order=&redirectFromAll=False&generalSearch_keypresses=8&generalSearch_suggested=20
Not sure how they'd go being split into two pairs though. I reckon 4 small throttles of some tiny engined runabout....
Guest lan_killa
It looks like they unbolt from the manifold. My flat mate is attempting to put 6x of those onto the 1GGE in his van, will quiz him when I see him next about how.
DO IT.
And I reckon one day it may be worth straightening the old RA. Heck, even reunite it with its bits. Money maaaaay become easier to come by as time goes on ;D
 Shale']
DO IT.
+1
and i got the perfect shell for you,
:evilgrins:
never liked the look of those tube frame desert racers..
going to investigate a legacy shell and build a runabout. still going to port the 1.6 and leave room for a t'bo though :)
question:
worth honing the bores and installing new piston rings on the 1.6? can that be done cheaply?
