Ryco Oil Filters... STAY AWAY
Changed oil on my girlfriends impreza today, new filter etc.
Turned engine on and the filter seal blew out pissing oil everywhere...
I am never buying these again, but for anyone considering buying them...
STAY AWAY
Save yourself the hassle and buy a good quality subaru one.
(Hope the buggers refund the oil and filter!)
i agree definately a fitment issue.
it takes about 300psi to blow a oil filter seal out if properly installed, and thats directly out of the Ryco tech book at work.
i fit around 500 aftermarket filters every month with no issues. apart from one which i have been dealing with this week, on a diesel vehicle, but that was due to the internal engine oil pressure regulator failing. im sending that filter away to be tested and find out exactly what pressure the seal popped out at.
As my time as a tech ive probly fitted 4 or 5 hundy ryco filters, not one problem, and probly 2000 genuine mitsubishi filters, not a single fault, BUT ive seen 2 " O.E " silver filters in the last 3 months, think they came from partmaster, not fitted by us, both had slow leaking split o rings. one killed a engine. I think you have made a fitting error, did you lube the o ring before spinning it on, if not it grabs it and can tear it if you over tighten it
I'm sure Ripco sell these too, i sometimes use them. Sometimes the Fram ones from BNT which are cheaper ($10ish). Never had a fault with any of them. Some say the Fram ones are nasty - but the grip thing is cool, it makes removing them a lot easier...since I've changed mine twice already in the last month or so
yea, and repco branded ones are ryco filters, just different colour.
