So how would one go about making a NA legacy a bit quicker?
cpt kernow
K,
So I went and got myself a 2002 TS-R for work. Didn't want a turbo as the extra 1.2l/100k adds up pretty quick when you clock 65,000k's a year.
But how could I make it a little perkier or more powerful?
Just seems a little weak on the hills, but everwhere else is fine.
  • Replies 102
 subieboy said:
buy a turbo...
To make an N/A subaru faster/more powerful requires a bucket-load of money, far more than the 1.2L/100 x 65 000km...
but if you have to 2" exhaust... manual gearbox...
I'd only own an auto when my left leg gets chopped off!
I figured it'd be breathing mods, was wondering if there was a ecu/chip remap or something.
There's also the insurance and running 95ron when going NA over turbo, not just econony figures.
 cpt kernow']
[quote name='subieboy said:
buy a turbo...
JAMIE! YOUR BACK! So you sold your Forester for the TS-R?
Prob go with freeing up the breathing and decat the exhaust. Might make a noticeable difference? I remember back when i had my pulsar i got better economy with a slightly bigger exhaust from the cat back and a little more power (or the power was in my head because of the rps exhaust).
Foz is there but for the weekends.
Traded in my old european deathtrap for the legacy.
My first legacy and after a week, I reckon it's the comfiest, safest feeling thing to sit in all day at 100kmh.
Quite scary though as it has the same wheel and gear knob as the forester and I have to remember it's not the same car and I can't overtake on a whim
 cpt kernow said:
Barely, mostly part time, tuesday evening and thurs afternoon this semester
Ahh ok, Im part time these days too, but mostly because of the health. I'll have to grab you for a beverage one day 8)
Guest loren
 Divine']
[quote name='loren said:
don't waste your money on mods, just drive it like you don't own it.
This.
Not in a boy racer like way though.
Guest the_return_of_the_jedi
you can do a pod filter and exhaust mods..
pod will give it a noticable gain on sound above 4000rpm..
make sure its secured tho or you could risk dropping the afm due to excess movement.
exhaust maybe some headers and a nice flowing mid pipe/exhaust..
failing that... well how long is a piece of string?
do you wana spend buckets of money on it?
1. Free up the intake, not with a pod though, you don't want it sucking in hot engine bay air.
2. Free up the exhaust with a 2" - 2.5" system.
3. Give it a dose of upper engine cleaner.
4. Reset the ECU.
5. Straight after the reset, go and give it a damn good aggressive drive, and get it to learn some performance data.
th_Coldairbox.jpg?t=1280013698
th_ram111.jpg?t=1280013698
of course, everyone knows if you want to have a pod filter, you should only use a pod with a cold air box and snorklectomy 8)
 cpt kernow said:
My thoughts sofar are a catback off a GTB if they're any bigger than NA.
And the thing is 200kg heavier than the foz at 1680 according to the recycle station weighbridge.
i doubt it would be 200kg heavier than a forester... but ya never know.
The rear section may bolt up to yours. I doubt the centre section will though.
 petrolheadjman said:
my own research a while ago said it was 1350kg but that seems a bit light
Subies stats are all done with the vehicle dry.
There's over 10l of oil, plus brake fluid, power steering 5l of water, screenwash and a tank of gas to add on to that
 the_return_of_the_jedi']
THis could be ok, but living in the country I'm often in puddles that'd hydrolock my engine before you could say "induction noise"
