v7 sti boost psi
Pappu1
what is ur standard car boosting?
mine used to do 18ish stock and closer to 19/20 with a 3 inch TBE
a "reputed" mechanic seems to reakon that they should only be doing 1bar aka 14.7 psi
i laughed at that but thought to as here to confirm
Ha ha.
Just went through this myself a little while back.
Actually rang Subaru NZ head technical manager to get a concrete answer. Although his answer was that if you were to take 5 stock V7 STIs they would all be different. He did say though that 16 was common.
I asked RLP who didn't know but said that their A/M exhaust system increased boost to 22 psi, but according to them wasn't harmful on engine, adding they had sold 300+ of them.
Discussed boost with Akld Subaru Specialists, ST Hitech, Wingers, even Steve Murch who agreed with the above in that all STIs varied, but 16 sounded right from experience.
None of the above suggested 14.7 (at least not to my understanding).
mine boost between 1.3-1.5 bar, stock standard i think, with only aftermarket tail exhaust, they should handle bit more power than earlier factory engines i would think.... but not to fond of the boost coming on late tho like 3800rpm grrr...
 Simon C said:
With a 3" exhaust and a VF34, mine would boost to 20psi, then gradually fall back to 14psi at redline.
If you put most stock newage Sti's on a dyno they do something like above. Thats how they are setup from the factory. With all the extra weight they gained over classic Sti they gave them more boost in the mid range to help acceleration.
There is no one boost figure as its different along the rpm curve
Most boost gauges are not that accurate
