STI ra
I can tell you now, that the second one is the one i'd go for.
The first one is a non-sti Ra. Basically an NA impresa with a turbo.
The second one is an STI Ra; way more good bits and a better car (unless your going to strip it and rally it), and then still probably a better base model.
Depends who you ask...
Ra is the Rally model, so being stripped out, without extra's and having wind up windows etc makes it a real RA.
However, there were also STI RA's made. They had more extra's, and were heavier (off the top of my head, i think around 60-80kg), but came with roof vent, DCCD, firm sti seats and better spec'd engines...
Much like the later Spec C's came in two flavours, one stripped out (RA) with wind ups, small brakes and DCCD, the other with electric windows, Brembo's and no DCCD.
Both, like the GC8 Ra's, were lighter than the equivilent STI model, but one was weighted in favour of comfort, and one wasn't... ;D
Again, off the top of my head:
GC8 STI: 1250kg
GC8 STI Ra: 1190kg
GC8 Ra: 1140kg
GDB STI(V7): 1490kg
GDB STI RA(V7): 1390kg
GDB STI Spec C (V7): 1340kg
GDB STI RA Spec C (V7): 1290kg
 Drunkenmonkey said:
yeah bit hard tho im in auckland :(
ahh sux, hopefully someone from c/s can look for you :) otherwise an AA test or some mechanical check the only option if your really keen.
so is there an easy way of finding what models what with out viewing i want the dccd, weight isnt a huge issue for me as its gnna be a everyday car which i want to use on track days for fun
The FHI manufacturers plate should have one of these transmission codes methinks (for GC8 w/ DCCD)
TY752VB3EA
TY752VB5BA
TY752VB5CA
TY754VB1BA
TY754VB1CA
And possibly these
TY752VB3BA
TY752VB3DA
TY752VBCCA
The four door STi RAs all seem to have GC8, then model year (A,B,C,D,E), then 4DD. There are variations including the Type Rs, the V-Limiteds, and the 22b. Assuming the car hasn't had everything replaced, you should be able to tell what it is just from the FHI plate.
Corrections welcome.
Definatly pay a little extra and get the second - which is clearly an original Version 2 STI RA. It has less than 100 000km's too!
I have had three Subaru's and I finally own a Version 3 STI RA which I never want to sell...! It was well worth the little extra $$$.
Here's a pic of mine.
