Whats my problem????
Hailz
Hello again fellow clubsubbers,
Ok here's the thing, sometimes I cant hook first gear - there's just nothing there, it kind of goes half in, it only happens very rarely but if I hook reverse straight away (which it will do with no probs) it slips right back into 1st easy peasy, I get the feeling this isnt a gearbox prob more likely a clutch issue but I'm no trained mechanic (clutch is only about 20,000kms old), I would like to just take it into the shop but due to the Chch quake Im rather limited to what I can get to :(
Any ideas peoples?
seems to be normal on a subaru box :) not quite engaging first,having to engage reverse first seems to be very common, i would not worry about it, ass u could spend alot of time/money trying to fix something not fixable :)
 JoKer said:
check clutch fluid and slave cylinder - I found a wee hole in the line between each was leaking fluid at about 180,000 kms
Yeah have done that, I bled it maybe 25,000kms ago and it was bloody dirty and has got that way again but has never used any, mite give it another wee bleed over the weekend and see what happens :)
But yeah I agree with ya's might just be another one of those "typical subaru traits"
What if your say sitting there and you cant get 1st . If you just let the clutch out in neutral and then push it back in then go for 1st ? If it goes in that would to me indicate the 1st gear synchro is a bit worn . . . Does it go into 1st easily when rolling ? By letting out the clutch and putting it back in your spinning the shaft in the gear box which would position it in a different spot where maybe the teeth just line up . . . .
yea i wouldnt say it goes in any easier when trying that trick man, you've stil got to argue with it, and nah it wont always go in with it rolling either.
Bloody confusing stuff aye, i just get the feeling if i take it to a gearbox shop because of the quake every company will want the money and convince me i need a gearbox rebuild
dog boxs dont run synchros...theyre an all together different beast...
the standard gearboxs do run synchros on 1st gear...easy way to tell is be rolling forward...can you select 1st gear?? yup they have a synchro on it LOL... if a box is worn out you can sometimes hear the synchro whine when selecting 1st while rolling... my old gearbox did this before it blew :)
 WRXONP said:
pretty dam sure it would or youd never ber able to get into first without grinding it LOL some gearboxs have a double cone synchro??
1st and reverse are straight cut gears
the rest are synchro
EDIT:
Here is some symptoms and resolutions:
Symptom Possible cause Remedy
1. Gears are difficult to intermesh.
NOTE:
The cause for difficulty in shifting gears
can be classified into two kinds: one is
malfunction of the gear shift system and
the other is malfunction of the transmission.
However, if the operation is heavy
and engagement of the gears is difficult,
defective clutch disengagement may
also be responsible. Check whether the
clutch is correctly functioning, before
checking the gear shift system and
transmission.
(a) Worn, damaged or burred chamfer of
internal spline of sleeve and reverse
driven gear
Replace.
(b) Worn, damaged or burred chamfer of
spline of gears
Replace.
© Worn or scratched bushings Replace.
(d) Incorrect contact between synchronizer
ring and gear cone or wear
Correct or replace.
2. Gear slips out.
I Gear slips out when coasting on
rough road.
I Gear slips out during acceleration.
(a) Defective pitching stopper adjustment Adjust
(b) Loose engine mounting bolts Tighten or replace.
© Worn fork shifter, broken shifter fork
rail spring
Replace.
(d) Worn or damaged ball bearing Replace.
(e) Excessive clearance between splines
of synchronizer hub and synchronizer
sleeve
Replace.
(f) Worn tooth step of synchronizer hub
(responsible for slip- out of 3rd gear)
Replace.
(g) Worn 1st driven gear, needle bearing
and race
Replace.
(h) Worn 2nd driven gear, needle bearing
and race
Replace.
(i) Worn 3rd drive gear and bushing Replace.
(j) Worn 4th drive gear and bushing Replace.
(k) Worn reverse idler gear and bushing Replace.
3. Unusual noise comes from transmission.
NOTE:
If an unusual noise is heard when the
vehicle is parked with its engine idling
and if the noise ceases when the clutch
is disengaged, it may be considered that
the noise comes from the transmission.
(a) Insufficient or improper lubrication Lubricate or replace with specified oil.
(b) Worn or damaged gears and bearings
NOTE:
If the trouble is only wear of the tooth
surfaces, merely a high roaring noise will
occur at high speeds, but if any part is
broken, rhythmical knocking sound will
be heard even at low speeds.
Replace.
52
