Replacing only one tyre
What are peoples thoughts on replacing only one tyre as far as drivetrain stress goes?
Ive punctured one 215/40/18 toyo and need a replacement (the sidewall is slightly rooted)
The current tyres have done about 10000k and are still far from needing replacement.
OK to put one new one on?
I would not do it personally
it will play havoc with your centre diff
i think a difference of 10% rolling circumference was banded about as the cut of point....
I have not had this happen to a subaru but have had a AWD hiace which uses a viscous centre diff,seize its centre diff because of different tire size....
it was only about 5k to fix
thats what diff's are for : go for it, mixing brands however is not recomended BUT not going to be noticeable
you MAY fail a WOF for having different brands (rules change daily so not sure if this still applies
