what engines would bolt up to a 89rs legacy?
SubLeggy
hey guys,
just a quick question: what engines would bolt up to a 89rs legacy? am looking at purchasing a 89rs but wanna swap the motor out of it for more reliability and power, have noticed quiet a few sti long blocks that are up for grabs.... would also be looking at a trbo upgrade and injectors.
cheers
subleggy
Old school Legacy motors are some of the most reliable... until you're a twat and freeboost them.
Then they start to look like this.
Seriously, not a hell of a lot to be gained by winding up the boost on an old grey-injector motor.
On a related note, if you're going to up the power with a new plant... for GOD'S SAKE do the brakes and suspension too :-X ie: do it once, do it right. If I see another munted, trashed and raped BC5 Legacy...imma go HULK SMASH.
On the other hand, if you've got every intention of putting a rebuilt/repowered motor in along with better brakes and refreshed suspension...hats off to you, kind sir ;D
But srsly...nothing wrong with the stock motor unless someone's popped it from serious neglect.
Look at my not-finished build though ;D Continuing on once I'm not a student any more, but have learned my lesson and am sticking to the WRX motor in Frankie :)
(And on that note, the WRX 20G motor and a TD04 are a good midway as they'll run on the old Legacy ECU and make a bit of power. Mine makes 135kW on GCP's dyno.)
yeah im not tryna blow it out of the water and have it thrashed to peices. just looking at having say 200-220kw relaiabilty for a daily driver and of course ill do it right first time as im not super rich. heres a list of whats been done to the car so far, cant get the pictures up cos the link wont work, but it was the bright yellow one on trademe:
Number plate: FEP615
Kilometres: 152,000km
Body: YELLOW, 4 door, Sedan
Fuel type: Petrol
Engine: 4 cylinder, 2000cc, Manual, 4WD
Registration expires: Jun 2011
WOF expires: Aug 2011
Stereo description: PANASONIC
Features: ABS brakes
Alloy wheels
Central locking
Power steering
Sunroof
Been a great reliable car
But want something different
1st photo has cutties in it, can come with car if wanted
Work done:
New cambelt
New cambelt bearings
New WOF
New REGO
New water pump
New radiator
New radiator hoses
New Munroe gas shocks
New dobinsons super low springs
New rebuilt steering rack
New Panasonic 222w cd player
New in-cabin boost tap and tee
New clutch fluid
New brake fluid
New coolant
New oil and filter
Also has:
40mm External wastegate
Anti-lag turbo
HKS turbo timer
HKS pod filter
18 inch DTM black with 2 inch chrome lip wheels
Near new tyres
2 stage exhaust pipe (2 into 3 inch) into 5 inch tip big bore
Bright suzuki swift yellow paint job
i know for one thing im gonna get rid of the wastegate and poddy! but let me know what you guys think, it is in auckland as well and for sale at $4,900
 SubLeggy said:
hey guys,
cheers
subleggy
You want to swap the engine because its stuffed?
More reliability - stick with standard engine/boost (using shales example 135kw)
More power - engine with better flowing heads (v3/4 sti)/more boost/chipped ecu/yellows (pass, maybe 160-170kw? still well under 200kw)
best of both - Fresh short block, V3/4 heads, Better turbo & IC, yellow injectors, walbro fuel pump, Link ecu (200kw+ easily achievable)
 pl0x']
[quote name='SubLeggy said:
hey guys,
cheers
subleggy
engine probably wouldnt be stuffed at all hopefully, but i ran a v4 sti long block in my old rs with a standard turbo and that had 140kw which ran bloody well for me but jut wasnt quiet enough and i had plans for that engine but some dumbarse driver hit me and the car couldnt be repaired so had to get rid of it
 pl0x']
hey guys,
cheers
subleggy
I ran a standard as "unknown" Km's rs engine with a TD05 equal length headers(Leaking badly) and V2 top mount on greys. Running 15psi i got 146kw at the wheels with misbehaving valves..
Here it is when it hits 6,000rpm...
LOL..
http://www.youtube.com/user/aKiwiJoKeR#p/u/49/7S6FNpZmiXU
