Miss accross the rev range
Pappu1
  • Replies 76
 kwi_fozze said:
check plug seating? ehh..... may as well do that after compression test aye
second set of plugs in there so seaterd good heheh
will take the coil out and see if it fires the plugs - just so i know if any spark is happening
cant understand why the dam passenger side both are being such b!tches lol
have you checked the 16 or 20 pin multi plug on the driver strut tower
Check it for engine oil, if present you have issues that no tune will fix
refer my AVCS post under ENGINE section
yea bro thats what i was going to do - see the plugs but have not had a chance
if the avcs sensor is all oiled up - will i have this issue??
also - i may look into getting ur mod done on the avcs setup...
can i pull the sensor out without openinig up the intake manifold?
 pappu']
Sensor s can be removed from both banks without removing manifold - thay are a tight fit tho , need skinny fingers
hahaha skinny fingers i have...NOT damit lol
will need to find a skinny fingered mate for that..
if the sensors are bunged (perhaps the passenger bank ones?)
then will it cause me such grief u reakon?
hmmm some more research and i have a different theory to try -
what if the damm avcs is blocked/restricted on one side
that wud cause it to have uneven timing compared to the other side
(refer to ici ban and his posts abt the banjo bolt filter being possibly blocked as an issue on avcs heads)
will see if i can log the differences in the avcs
ichi ban could be onto it...........check for oil in your avsc plugs!..Hope its not internal damage. Compression test will reveal if it is or not. Then it must be electrical,.
Yea I'm thinking thats the path
I'm just waiting to get the compression test done to confirm no broke rings
Then next few ideas in place
Damm I cNt cross me fingers hard enough for good compression test
update:
compression test - ~135psi on all 4 cylinders
(been informed that is within spec and no leak as all are same ish so all good there)
logged AVCS angles
- the passenger side bank seems to have 53 degrees at idle and rises as revs rise a bit (only reved to 5500 ish rpm)
- the drivers side remains stuck at 0 no matter how the revs rise
outta comparizion i checked a working v7 sti and both sides avcs remain 0 at idle and rise together as revs rise
currently issue seems to point to avcs filter fallen in the valve and causing issue s
next step is to pull out the filter basket and also pull out the avcs solenoid and clean
will update how that goes
passenger side looks easy-ish but drivers side looks harder..ah well ...
as we discussed you only need to sort the passengers side for now
The 53deg IS the issue, and will be either the filter basket in the valve
or incorrect cambelt timing
yay the easier side ay bro... ;)
PS - why wud the driver side stay stuck at 0 degrees all the time tho?
normally as the revs rise the avcs degrees rise alongside...
do u think the avcs on passenger side is causing the constant 0 on the drivers side as well??
PPS. once i get this sorted im going to do a writeup with pics on a troubleshooting for v7 ppl (with credits to all thoes who have helped out)
issue sorted !!! ;D
opened the banjo bolt for the oil feed on the left (as the logs had indicated left side advanced)
found the banjo bolt filter - had mostly disintergrated
removed filter
started car - same issue - slightly beter (50 degrees advanced not 53 lol)
opened the avcs actuater and found a tiny piece of broken filter basket plastic in the lobes and jamming it open
removed it
put all back
started car... success ;D
will do another thread of writeup on the issue for others to follow
thanks to all who have helped with their suggestions and advice
major thanks to ichiban for giving me the confidence to do the job myself and pointing out the details
and also to crazymf for the vote of confidence and showing me to parts
and to teznu for helping with the compression test
Hey mate, glad you got this sorted, might check mine cause Ive just found some oil in the big connector by the driver side :(
is there any harm in removing the filter? Did you have any oil in your loom connector at all from this ?
thanks
thanks
yea man found oil in my loom connector as well >:(
dam silly design by subaru
and no - removing the filter makes no issue bro
yea gazzy hehehe been thinking of doing like a symptom and diagnosis and repair type writeup
defenetly v7+ ppl will need with the silly filter in banjo bolt
 jpar196 said:
Sweet, will need to do that, do you know if removing the filter then will stop the oils travelling in to the ECU looms ?? not smart design for oil to allow to go to the ECU :(
na bro - removing the filter will stop it fallinf in the avcs actuator and causing issues
to stop oil in loom - u gotta get ur avcs cam position sensors modded
iciban on here does modded sensors
i will be getting mine done soon
can do a writeup on that too so u (and other can follow) with puting the modded sensors eh
