Does any one in chch have a muffler for a wrx i can borrow
Does any one in chch have a muffler for a v7wrx i can borrow to get cert??
Is a 2 1/2 inch exaust I think, need to get noise down to 92 for cert is currenlty at 96 >:(
Would be good if I could borrow one for a day so I can pass, cheers
there's this material you stuff into your exhaust.it will also take it down a few db's
it's sort of this thick meshy stuff.dont 100% sure off the name of it
I think your thinking of goldilocks (unsure of spelling) ya no that wire sh1t you use to scrub dishes with lolol . It's just metal shavings pretty much
yehyeh same thing as you use for dishes.i used it on my skyline..i got it from 109 db down to 92.3db,all i added was a shit load of that stuff and a silencer,
now days silincer has to be welded so you cant remove it.
yupjust stuff it all in one bit.then when your done use a coat hanger and pull it all back out,thats what i did,also only tacked my sillincer in the exhaust so i could remove it easyer
I've been told a trick you can do is craft up a bit of steel with a smaller diameter hole in it to allow flow through, and use as a gasket between your muffler and center sections of your exhaust. Cuts flow down a lot, and also the noise. After your wof / cert, remove it and replace with normal gasket again.
Just don't boost with it in as it restricts the flow a lot.
Yea think i might have to do that, the guy doesn't seem to worried about having it welded in cause its not at the moment and he hand't said anything about it which is good, hopefully he won't look up it and look at the goldilocks, have already tried restricting flow but didn't make much difference to sound unfortunatly
what does the exhaust consist of at the moment, I would add a centre Muffler as when it comes down to it 95db is the legal limit and it should be below that at ALL times so as we dont attract attention of the po po :) just make it legal in the long run waayyyyy easier ( i had to add a centre muffler on my RX as it was deemed to loud :( )
