AN Fittings
Hey guys not really sure where i should post this up, so forgive me if im getting thing wrong
Im after a whole bunch of AN fittings and line for a new fuel set up
does anyone deal with them, or know where i can get what i need without breaking the bank??
Cheers in advance
Ryan
And while you are at it, dont buy cheap fittings either... they have been known to fail. Its not worth the risk when dealing with stuff like fuel, and oil cooler lines IMO.
GSS has all the good quality fittings - I would recommend them (be prepared to open your wallet though).
I have used the M&H ones from STA and found them good, I know Optical found a leaking one but I have maybe 15 on my setup and they are all good.
+1000000 on the good hose tho, its easier to use, its easier to cut, it fits in the fittings and wont pop off and explode under more than 2psi.
The ones that leaked for me were the swivel fittings from STA, straight out of the box shitters.
I haven't had any trouble with fixed ones from STA, but using Earls, speedflow, FRP or XRP fittings saves you headaches and paranoia for a bit extra $
