Catalyic Converter Scrape
Lampard
 ADIKT said:
Hes got a standard b4 and standard height... and wants to lower it! your going to run into worse scraping when you lower it more! park infront of the garage?
haha, yeah I guess I could do that. I'm not so into parking outside. =P
what you can do is build up the driveway a little at the right point to lift the rear wheels a little higher when the cat scrapes. i.e. stop car right on the point it scrapes. Get out of car. Mark position of rear wheels. Move car. add cement/wood/sand/plastic hump, whatever. probably 500-1000mm in length would do it. would only need to raise up an inch or so.
