200,000 k service?
Kiwi_Fozze
hey guys, I'm rapidly approaching the big 200,000 k service, and lets face it, I'm a little nervous as to what it's going to cost me.
it will need EVERYTHING done, dif oil, gbox oil, engine oil, coolant, rocker cover seals, new sparky plugs, cam belt and the works...
I'm wondering, is it worth doing? or should I nurse it until I can build up a reasonable engine?
looking at a bog standard v5/v6 sti engine, or if I can build one from parts etc I'll give it a crack.
budget is TIGHT.
i can do a lot of work myself, just unsure on exactly how to go about it, and this car being my daily driver, it can't come off the road for anything longer than about a weekend....
any advice?
Upper Engine Cylinder cleaner?
Check coils and coilpack?
Check all the belts
Are your rocker cover gaskets leaking??
Clean the IACV and replace the gasket?
Check and adjust tyre pressure??
Change fuel filter?
Add some injector cleaner??
Check battery?
Give the AFM a clean with AFM cleaner
Check and replace air filter?
Check all the belts
Change fuel filter?
Check battery?
I ALWAYS replace the accessory belts at the same time as I do the cambelts :)
im sure the Haynes Manuel has a step by step for the cambelt change .
i didn't use it and its not to hard ..... all the timing marks are there but i did it with the engine out.
but with the radiator out you will have enough room to see the timing marks.
otherwise for a shop to do cambelt,tensioners, oils ect is going to start getting up around $1500 quick
Parts end up costly to do it ALL. Heck bought a auto tensioner only bout 2 days ago and had forgotten their price >:( lol. $225+ GST retail at repco. 155+ @ repco with trade account. still got 4 idilers and a belt to go!!! Then thers cam and crank seals if your doing it ALL. Gets up there but ppl have said about right. Misus GDB was done by shop (cus of mechanical warranty) last year cost $1750 doing all cambelt stuff + plugs and engine oil,filter,coolant and a general check over.
