Max Power from a VF30
xsvpwr
well if u do both combo then u get a really good power, ichi ban's engine got kelford cams and gt28 turbo on a possum link got 250kw on a ver 5/6 sti heads
power fc is good but a newer G3/G4 link is more better and easier to tune by the tuner
  • Replies 75
hmm yeh but im not planning on going down the g3g4 road.
iwana use my car as a daily.and have good reliable power too.230 isnt to much to ask for,but i need to get the basics first.
i think a power fc and a decnt tune should be able to crack 230,but i dont think my turbo has it in it.
im not too keen on doing cams just yet.would rather go for new turbo.fueling mods and a good tune,then later work into a forged block with cams..
yeh 200 220 stock
im hoping for 230 with support mods
im sure by pbms block should be ok.they said it would be good for around 220 when they built it.but the turbo will be maxed before then anyway.
im hoping the newer style bearings and modded oil pump will help beb not to hapen ether.but only time will tell
yeh they said they motors good for around 220kw but my stock turbo will be maxed out before that.
thus is the reason i wana upgrade.hmm duno,ihave but!ilove the quick response of the topmount.especially with the 23
correct
ithink a setup including
vf22 vf30 td05 18g-20g-twitsed setup
headers with external port
power fc
rebuilt ej20k
silicone intake with ca
front mount
walbro with mayb a surge setup
that should see a good 220 230 kw imo.
 sti8u said:
correct
power fc
rebuilt ej20k
front mount
I have-
VF22
FULLY TUNED headers with waistgate from turbo housing as above
LINK g4 with antilag
Front mount
Walbrough 500hp with pink injectors
3" DEAD straight exhast
Direct turbo intake
v7 engine
Tuned with VCT and AVCS
hmm yeh td06 i here is a good unit.
havnt thought bout going for a garret unit.gt30 or so?
lil bit more expenssive,but well worth it in the long run.im sure the v7 engine will help spool it up good.haha
Was almost thinking gt28R so theres minimal lag with good results. but the $$$ for a garett is ^^^^
a 2871r is a good unit, you'd be looking mid 250's with that.
the 3071r with a good measure of boost will see about 300.
a 2876r in my opinion is too unbalanced (in wheel size for ej20 ) and you see a laggy 250-60.
for the $$ in doing the conversion and it is $$$$ maybe staying on a td 18 / 20g / vf based turbo and doing cams is as cost effective as a turbo conversion.
im not sure whats the deal with tmic to fmic and lag
there maybe a slight slight bit
but in all seriousness its more than worth to do the fmic
ps. so pmbs say the vf23 will max out before 220 -
they told me the same as well
not sure why ppl say it will get 230... ???
 funkytown said:
its mostly not even required, launch control will do the trick if you need to get away smartly - and its not nearly as savage on your exhaust and turbo components.
Not to say we wouldn't like it- its certainly a bawse mod, and wins e-peen fights any day of the week ;D
Hahahaha its got quite bad lag without the anti-lag though, seeing the big rip you out the seat feeling at about 4100
not sure brad proved a few people wrong thoe with his setup.and his af ratio was still mint.
yeh they told me that,considering my turbo has 125thou ks and my motor 15 thou ks,idont think it would be capable of it ne more.mayb when the turbo was new.this the reason being i wana upgrade,and why not when you hava turbo builder on the forums that can make you a custom turbo.lol
 sti8u']
Didn't it get fairly well established that the number he pulled was at least somewhat generous on the dyno's behalf?
LOL you guys crack me up
it was "established" was it
I think all you lot need to step back...there is FUCKLOADS of ways to make power and turbo is only the start of it
i ran 200kw on 1 dyno. more mods on a different dyno and got 215.. more work and got 222 on a different dyno.. re did the current mods and got 233 at TP..
All in all its just a number that doesnt mean shit really??
quarter mile times and trap speeds show a fast car and a decent driver
BTW mine was on a fully stock un opened EJ20G !!! YES G - non sti
like i said think outside the sqaure theres alot more to making power than which turbo is strapped on the side
