Suspension upgrade
What's your budget? The sky is the limit...
Some people swap in V7 struts (I think?) which offer a decent handling upgrade without needing a cert.
If you want to go the whole hog, you can get adjustable suspension, starts at around $600 for something reasonable second-hand on Trademe (allow $500 for getting a cert) and goes all the way to... well, I dunno? $7000 or so for a full Ohlins track-ready setup brand spanking new?
inverted struts, stiffer progressive springs, stiffer adjustible swaybars, solid endlinks, k bracing, underbody bracing, front and rear strut braces, there are a few cars in the states that have 3 or 4 point strut bracing in the rear, amazing looking set up.
replace all your bushings with new bits
antilift kit / new caster bushings
basically, find the whiteline performance parts catalogue and select all hahahaha
