SUB Pre-Out Question
sushi2hot4u
Hi everyone. First off thanks for viewing the post and feedback in advance..
Now whats been puzzling me. I have pioneer pioneer gm-d7400m Monoblock Amplifier and Sony 1300watt subwoofer. The amp has L+R Pre-Out RCA input.
On the back of my headunit, I have 3 RCA inputs: Front L+R Pre out , Rear L+R Pre out and single SUB Pre out.
What is the single SUB Pre out at the back of the headunit for? Is it for an active subwoofer?
Should I match and connect L+R pre-out on my amp to L+R (front or rear) at the back of the headunit?
Sorry if ive confused anyone.
 Scoobydoo said:
It's a mono signal, as opposed to the front & rear, left and right stereo signals. Use the subwoofer pre-out.
Subwoofers do not particularly like a stereo signal.
So since there is only single sub pre out as opposed to L+R pre out on amp, how would i connect them up?
Usually amps with 2 sets of inputs for mono output use a very simple 'summing' circuit (aka run the 2 channels together). The only time this can be a problem is if the 2 channels bass signal is out of phase (as they can cancel each other out) although this is extremely rare.
 Scoobydoo']
[quote name='spark_38 said:
Isn't the left channel usually the mono input?
If you are talking a stereo signal, then maybe, but that's not the case here. He is using a Mono (1 channel) amp with a mono signal (sub pre-out) so it makes no difference.
Well its a monoblock (1ch) amp so essentially if I understand it correctly, just connect mono L(or R) RCA from the amp to mono sub pre-out at the back of the headunit?
