High Pitched Noise from Wheel and Occasional Clunking Noise??
subypower
Recently my BH has started to make a few strange sounds, both only happen when the engine and car are really warm,
The first is a high pitched noise coming from the back left wheel which comes on when the car is warm
and sometimes turns off when I turn around a corner.
The other, is a clunking thuddding noise which has happened twice at the end of a long trip when I
turn the steering wheel until it locks and then drive. I can feel it through the steering wheel as well.
Any ideas? I thought it was a stone in the brake at first but it only comes on after a good half an hour?
I had also thought it could be one of the CVs or Centre Diff??
Cheers.
 subypower']
Answer: stone(s), brake pads/disks
Answer: Centre Diff, would not be betting money on a rear diff as all of it is going on the centre diff...
 subypower said:
Drove back from Taupo to HB today and clunked as I turned into the driveway. Drove it two hours later to see if old man could help diagnose it but nothing happened :-\ was perfectly fine.
Centre Diff...
Take it to a Subaru Specialist that and describe to them whats happening...
mates one was doing the same and was also center diff - is it automatic by any chance??
the rear noise sounds like brake pads could be down to the wear strips (squeel tabs)
pull the wheel and look in side the caliper and you should be able to see how much meat is left on the pads
wheel bearings normally grind / droan more than a high pitch sound
