Miss at 5000revs on boost
JWDRPN
finally got my car running mint!! with new afm new fuel pump!!
but noticed today when driving at 80kmph then boosting to 100kmph it was pulling nicly till 5000revs where it had a miss.
now it will drive off boost without missing.
no check engine light.
im thinking crank angle sensor maybe.
car is a ver7sti
my car comes onto boost fine. just in the higher revs
my car feels like dogs ass when cold fukin struggles on the hill out of my street but obviously i dont boost at all when cold.
im thinking they may all be the same issue.
Try 0.7 gap and see if sorts it out
Factory spec is 0.7-8
Also a scanner will indicate if there are Any faults registered especially if it's been missing on any cylinder
Possible coils as well
Does it do this when hot as well?
Does it boost ok past 5000 mark all the way to redline?
Ecu will not reset with battery off in these v7
Need to manually reset it
In any case it will automatically pick up if the afm has been changed
Ur mechanic can reset it with scanning tool while checking for any Exsisting codes
Depending on what area I can scan/reset as well if u want
dunno once i felt the miss i backed off so i wouldnt know
i only boost when warm so thats really all id know im just saying the car is jerky as hell when cold
other than this driving is mint!!
is a full reset connecting the black and the green connectors?
 Stoffa said:
take it to someone who can check the fault codes properly, subie mechanic or alot of auto sparkies can do it these days. Just cos you didn't see the engine check light doesn't mean theres no fault codes logged
thats twice its been suggested now
