Miss at 5000revs on boost
JWDRPN
 pappu said:
ah dang..hopefully can get it when ur mate comes over next ya
what u end up putting on?
abt scan - yea sometimes it logs a code but does not always flash a cel
maybe the ecu has a list of non cel flas codes i suppose
I had spoken to him abuot it last night and I got up early before he left but morning haze maybe? Forgot about it before he left. Ill see if I have to come up this week and ill throw it in the ute.
I got an HKS off marc but the muffler has blown its guts out so thats a good waste of money too!
ok just got home from the mechanic
obdII hooked up nothing at all on there so he cleared the codes (was told that was the same as a reset) im guessing its not
back to the drawing board
my next plan is to change all the plugs
you dont need to change the plugs if they're only new, just get some feeler guages and regap them to the correct size
If its copper plugs then they probably past their use by date - bkr6e or bkr7e (depending on boost and how u drive it) work well and are cheap - good for 5-10k before they start to break down - cheap as only 28 for all 4 at retail price - come factory gapped to .8 unless stated as bkr6e-11 (that's 1.1 mm gap)
I had same issue. Tired cleaning air flow meter, new fuel filter and coil pack then found that it was a plug.
I put these NGK PFR6B plugs in. Factory gapped at 0.8. Have worked wonders! Your looking at around $30 per plug, but well worth spending the money.
Fortyone, a sponsor here, sold me a set for $70 :)
 Timmah']
Fortyone, a sponsor here for a set for $70 :)
JWDRPN If I were you I would snap up that deal!
Like all plug conversations - it depends on the owner - if you feel like changing your plugs more often go for coppers - copper is a better conductor than platinum or irididium - platinum and iridium do last longer that's all - its not a bright idea to change plugs to the longer lasting ones and just forget about them
Plugs tell a story - they're the window to your engine - no shit quoted from mr rick himself
stock v7 is 7 ngk
but using 6 or 7 really wont be of any difference if ur still on a stock tune and turbo
as long as the plug gap is 0.7-0.8 thats the more important bit for now
as been stated before ...just gap it correctly ya - also could just be a cracked insulater on the plug that can also cause miss issues on higher rev/boost
and if its not plug then could be coil
a mate had a similar issue and turned out to be 1 coil which we replaced yesterday - works sweet now
\usually ecu will log it as well - depending on what sorta scanner u use as i believe not all will read hidden codes (or so i been told)
have u made sure all ur boost hoses are tight and bov tight etc
a leajk can also cause surging that can feel like a missfire once boost builds up..i had that when my fmic piping silicone was slightly loose..only missed/surged after 5000rpm ..
that is a free fix so check all hoses
 pappu']
stock v7 is 7 ngk
the thing is theres so many hoses lol i also have a set of coils 2 replace, mine were checked tho and said were fine, but will try these 1s,
have u checked ya fuel pump?
